2006 L3940 Seat issue
   / 2006 L3940 Seat issue #1
okiecraig
Creek County, OKlahoma
1972 MF 135 diesel, Kubota L3940
Need Forum help once again. :) The seat back has lost the ability to remain fixed where placed by the adjustment handle on the left hinge (see photo). I need to remove the hinge cover to investigate. I removed the small black bolt that appeared to attach the adjustment handle to the seat. However, I cannot get the cover off! The adjustment handle seems to still be under tension even with the bolt removed.
Any suggestions?
Thanks
   / 2006 L3940 Seat issue #2
It might be glued on there or else there is a special release tab.
Solved this one. Used adjustable pliers to gently grab seat handle and pull straight out. Then cover was easy as only held by 3 tabs. The bolt that came out of my seat fell out of the cover when removed, reinstalled, problem solved. LOL. Thnaks for all views and comments......:)
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
set of 4 wheels and tires 205/75R15 (A56435)
set of 4 wheels...
2014 Ford F-150 (A55973)
2014 Ford F-150...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
72in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
72in Dual Cylinder...
