2006 F-350 Dually brakes, regular vs drilled and slotted rotor replacement
   / 2006 F-350 Dually brakes, regular vs drilled and slotted rotor replacement #11
Drilled and slotted rotors run cooler compared to solid rotors because of air flow. Has nothing to do with plain rotors being a "heat sink" or thermal mass. LOL.
I've run drilled and slotted rotors on everything I own and never had any kind of problem with them and I feel like I get increased performance.
   / 2006 F-350 Dually brakes, regular vs drilled and slotted rotor replacement #12
Brake FAQ, mythbusting, and why you may not want a big brake upgrade | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum
Yes, although it's for cars there are still facts that are applicable to trucks.
I run stock rotors (Zimmerman) and Akebono ceramic pads on my TDIs. I've never encountered an issue of brake fade: if I were to go to the track, then, yes, I'd likely get brake fade.
Best is to make sure you have good, clean mating surfaces (pad-to-rotor as well as pad to caliper) and properly greased caliper pins (and that the pins are not pitted).
The engineers who designed the braking system know what they're doing. Some slight improvements can be had with newer materials, but in general (and as noted in the above linked article) what might appear to be better aftermarket stuff isn't necessarily better than stock.
Sometimes rotors' can be thermally damaged and that damage cannot be seen: I've actually pulled off rotors that had metal "delaminating!" Some warping may occur after which turning/truing them the issue returns: been there, done that! For me and my cars the cost of new rotors is negligible: for these and other like-trucks the expense is more of a factor; my truck doesn't see enough mileage that I have to be concerned with replacing the brakes on it for probably the rest of my life.
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2018 MACK CHU613 DAYCAB (A58214)
2018 MACK CHU613...
DRAFTING TABLE (A58374)
DRAFTING TABLE...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
