Buying Advice 2006 Challenger 287B
/ 2006 Challenger 287B #1
lb-farmboy
Jennings, La.
Valtra 800 and Valtra 900
Does anyone know anything about this machine as far as dependability and functionality?. The dealer says it is a hydrostat......it is an 8 on a scale of 1 to 10, cab model, everything works, interior very good, no loader and has around 800 hrs.. I understand that this is the same as the Massey 1500 series, if I am correct! Are parts still available?? Price is 17,000 out the door!
/ 2006 Challenger 287B #2
I looked on Tractordata.com and didn't find the 287B, you might want to verify the model. As for parts and reliability, you should have no problems. Parts are available and the tractor would be almost the same as the Massey's.
/ 2006 Challenger 287B #3
It is the same as the MF but painted yellow. Parts are still available but ask for MF parts because they are cheaper. Verry good tractor,
Thanks droptop and jlsmith for the replies. Is this tractor made my Massey or someone else? jl.....sounds like you are a true "Massey fan", certainly nothing wrong with that! Pls. reply....Leland B.
/ 2006 Challenger 287B #5
I don't know much about these, but a used 1500 series without a loader probably wouldn't command that kind of money. The cab does make a difference and cabs are expensive. Still think it's high.
/ 2006 Challenger 287B #7
The big Challengers are built by Cat. As mentioned above they are built by Iseki of Japan. Same as a Massey only yellow.
/ 2006 Challenger 287B #8
Actually, the MFWD Challengers are built by MF, painted yellow. Not sure if AGCO owns the plants where the track and Mt 900 are built? They will soon all be SISU powered, opening the door for the Vario transmission.
/ 2006 Challenger 287B #9
I just read that AGCO just expanded their plant in Jackson, MN where the tracked Challenger and big 4 wheel drive tractors are built. They began building the MF 8600 series their, moving the production for the North America back from France. Finally something being made in the US.:thumbsup:
Row-Crop Tractor Assembly Begins at AGCO Jackson
Mini Universal Wheel Barrow (A65640)
Mini Universal...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
John Deere 5M Series Tractor Loader Frames (A65640)
John Deere 5M...
