Oil & Fuel 2005 DK55 Glow Plugs
/ 2005 DK55 Glow Plugs #1
jvanbrewski
Tuttle, Oklahoma
2005 Kioti DK55, 1985 Shibaura SD2243
Recently, I had a glow plug go bad in my tractor. I called the dealer, and they had 1, and wanted $49.95 for it! I couldn't beleive it, as I was considering replacing all of them. For those of you that are dealers, I realize that you have to stay in business, but come on! $50 for a $8 part? So, being the resourceful individual I am, I went seeking replacements. The glow plug is manufactured by Beru, world leader in glow plugs. Here is the message I got directly from them regarding the 0100 226 393 11v that is in this tractor: "Unfortunately this glow plug was taken out of our program some time ago and we do not offer any replacements". (lovely!) I did some extensive research, and found that the NGK's Y106-v Will fit into the combustion chamber, and will seat correctly. The only problem is that they are about 3/4" shorter. That means that you can't use the bus bar for the electrical connections, so I made some jumpers out of #6 wire and crimp terminals. Make sure you thread the knurled nut that comes with them, all the way down to the bottom, and add your electrical connections on top of that. The Kioti hardware that came off of the old glow plugs fit the new ones. Works Great! And, I bought them at O'Reilly Auto parts for the $8 I mentioned above. I'm sure there may be other cross reference's that may work, but this was my success.
Also, make sure if you replace the OEM oil filter with a Wix, use the 51324. The 51182 works as well, but is longer, and you won't be able to get the side engine cover on. (Real experience)
/ 2005 DK55 Glow Plugs #2
Very interesting, my plugs haven't went put yet but the info will definitely be wrote down
/ 2005 DK55 Glow Plugs #3
jvanbrewski
I have a Kioti LK3054, mid 90's year model I believe, it uses E6301-65512 glow plugs which are quite expensive and I too have been searching for a good cross reference for this part. I have probably spent 10-15 hours total before finding this post. I wondered if the glow plugs you are referencing are the same part number?
/ 2005 DK55 Glow Plugs #5
Do you have a photo of what you did?
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
Multipurpose Skid Steer Mount Backing Plate  (A62679)
Multipurpose Skid...
PAIR OF TRACTOR TIRES AND RIMS (A65643)
PAIR OF TRACTOR...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
