2000BD king pin
/ 2000BD king pin #1
FL_Jerry
FL, Bay County
YM 2000
I'm trying to replace the king pin seals and I'm having a little trouble
getting it out.
I remove the nut and washer from the top and removed the gear/bearing from under side. Only thing left is the shaft with the needle bearings.
Any tricks to getting it loose?
This may double post, but the first attempt didn't show up........trying second time.
/ 2000BD king pin #2
Jerry - If I knew the answer, I'd be sure to tell you - Someone will know though - Good Luck!
/ 2000BD king pin
I got one out, and good thing I did , seals are shot.
Thanks.
Jerry
/ 2000BD king pin #4
Jerry,
I was about to suggest that the only item that could be hanging up the king pin would be the wood-ruff key. Once that is removed it's often necessary to de-burr, file, or clean up with emery cloth, the key way on the king pin.
I've had them slide right out after a little touch up...of course in the real world it takes a little persuasion from a big dead-blow or lead hammer.
Good luck,
Mark
2012 CATERPILLAR CP56 PADFOOT ROLLER (A65056)
2012 CATERPILLAR...
1988 Ford 7610 Series II 4WD 97HP Agricultural Tractor (A66734)
1988 Ford 7610...
2001 FORD F-250 SUPER DUTY (A67714)
2001 FORD F-250...
Unused 2023 Monroe Tufline TW693222 12ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
2023 TAKEUCHI TL10V2 SKID STEER (A65056)
2023 TAKEUCHI...
2021 POLARIS PRO XD 4000D UTV (A65057)
2021 POLARIS PRO...
