2"X48" belt grinder
   / 2"X48" belt grinder #1
digr
Duluth MN
30 bocat, 1951 Case VAC
Sure is a handy little tool, built from pieces I had laying around with zero cost.
   / 2"X48" belt grinder #2
I have been looking for something like that, but mostly I find junky consumer offerings or really expensive industrial ones.
   / 2"X48" belt grinder #3
LOL. I also made a similar belt grinder.
Needed a few tweaks B4 I had it right but was a fun project.
Learned that a domed pully was a key to have good tracking as well as an something to pivot that domed pully.
Nice project and very satisifying to complete,
Probably could have purchased a similar one for a fraction of my time cost, LOL.
Yes the upper is domed and is made to pivot, one can't count ones time on a project like this. They do want a pile if money for a grinder this size.
   / 2"X48" belt grinder #5
Nice work!
   / 2"X48" belt grinder #6
Yep, same here. $50 piece of junk or $1750 professional version. :(
   / 2"X48" belt grinder #7
So, you had the two aluminum wheels just lying around? What were they in their previous life. I want to build a 2x72 for shop work and knifemaking. Wheels are expensive!
   / 2"X48" belt grinder #8
previously a machinist, i appreciate your work. what is your primary use? sharpening?
maybe a little more clearance on the left would be nice for longer precise work such as w/knives ?
very clean workmanship
Thank's a lot
I use it for metal fab work mostly and sharpening lathe tools, drill bits and such. but hardly a day goes by without using it for something. As far as clearance I had to fight those capacitors threw out the build, I thought about moving the motor mount but it would have just moved the problem to a different area. No knife making going on here.
Ted
   / 2"X48" belt grinder #10
hey great Ted...again great job. i sure do miss my machinist days & glad to see the trade (in whatever form) is still alive
The large wheel came from a junk shop for $2.00 but it had a U shaped one inch thick rubber glued on that I had a **** of time trying to get off, finally used a band saw to cut it off, then made a shaft on the lathe and turned the rest off. For the smaller pulley I used a hole saw on a piece of two inch aluminum plate and finished on the lathe.
   / 2"X48" belt grinder #12
Nice job on the grinder.
I have to make one one these once I get caught up on projects.
   / 2"X48" belt grinder #13
I started with the 1x30 HF grinder then got a 1x42 1/2 hp grinder. The 1x42 grinder is 10 times better than the 1x30 HF grinder. After watching Mr Pete 222 build a Kalamazoo style 2x48 belt grinder I built my 2x48 1 hp grinder. 10 times better than the 1x42 grinder. I had a 1 hp motor from a Craftsman table saw and most of the metal for the build. Purchased the wheels and a piece of DOM. I have a little over $100.00 in the build. With the 2x48 belt grinder it will help with a build of a 2x72 belt grinder using plans from Jeremy Schmidt (check out his build on UTUBE).
If you have a bench grinder look at the multitool grinder attachment 2x36 @ $215.95 or 2x48 @ $349.00.
or
Kalamazoo 1x42 1/3 hp $330.00
Kalamazoo 2x48 1/2 hp $509.00
   / 2"X48" belt grinder #14
Just wondering if anybody has tried to smelt old aluminum metal to cast the big aluminum pullies. It is something I have thought about, but been afraid to try. I have a buddy that cast small aluminum parts. He uses old transmission cases or other busted parts and melts them in a homemade forge. He then uses some sort of green sand to make his molds.
   / 2"X48" belt grinder #15
Look on YouTube for a man called mrpete222. He recently made a video about fixing up a belt sander. And he has many videos of casting parts from aluminum, including wheels for a belt sander.
UNUSED FUTURE FT50-(50) 12' PIECES OF GALVALUME (A60432)
UNUSED FUTURE...
5th Wheel Hitch (A59230)
5th Wheel Hitch...
1453 (A57192)
1453 (A57192)
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
2019 Ford Transit Connect XL Cargo Van (A59230)
2019 Ford Transit...
2022 KAUFMAN 2 CAR TILT GOOSENECK TRAILER (A59905)
2022 KAUFMAN 2 CAR...
