2"X48" belt grinder
/ 2"X48" belt grinder #1
digr
Duluth MN
30 bocat, 1951 Case VAC
Sure is a handy little tool, built from pieces I had laying around with zero cost.
/ 2"X48" belt grinder #2
I have been looking for something like that, but mostly I find junky consumer offerings or really expensive industrial ones.
/ 2"X48" belt grinder #3
LOL. I also made a similar belt grinder.
Needed a few tweaks B4 I had it right but was a fun project.
Learned that a domed pully was a key to have good tracking as well as an something to pivot that domed pully.
Nice project and very satisifying to complete,
Probably could have purchased a similar one for a fraction of my time cost, LOL.
Yes the upper is domed and is made to pivot, one can't count ones time on a project like this. They do want a pile if money for a grinder this size.
/ 2"X48" belt grinder #5
Nice work!
/ 2"X48" belt grinder #6
Yep, same here. $50 piece of junk or $1750 professional version. :(
/ 2"X48" belt grinder #7
So, you had the two aluminum wheels just lying around? What were they in their previous life. I want to build a 2x72 for shop work and knifemaking. Wheels are expensive!
/ 2"X48" belt grinder #8
previously a machinist, i appreciate your work. what is your primary use? sharpening?
maybe a little more clearance on the left would be nice for longer precise work such as w/knives ?
very clean workmanship
Thank's a lot
I use it for metal fab work mostly and sharpening lathe tools, drill bits and such. but hardly a day goes by without using it for something. As far as clearance I had to fight those capacitors threw out the build, I thought about moving the motor mount but it would have just moved the problem to a different area. No knife making going on here.
Ted
/ 2"X48" belt grinder #10
hey great Ted...again great job. i sure do miss my machinist days & glad to see the trade (in whatever form) is still alive
The large wheel came from a junk shop for $2.00 but it had a U shaped one inch thick rubber glued on that I had a **** of time trying to get off, finally used a band saw to cut it off, then made a shaft on the lathe and turned the rest off. For the smaller pulley I used a hole saw on a piece of two inch aluminum plate and finished on the lathe.
/ 2"X48" belt grinder #12
Nice job on the grinder.
I have to make one one these once I get caught up on projects.
/ 2"X48" belt grinder #13
I started with the 1x30 HF grinder then got a 1x42 1/2 hp grinder. The 1x42 grinder is 10 times better than the 1x30 HF grinder. After watching Mr Pete 222 build a Kalamazoo style 2x48 belt grinder I built my 2x48 1 hp grinder. 10 times better than the 1x42 grinder. I had a 1 hp motor from a Craftsman table saw and most of the metal for the build. Purchased the wheels and a piece of DOM. I have a little over $100.00 in the build. With the 2x48 belt grinder it will help with a build of a 2x72 belt grinder using plans from Jeremy Schmidt (check out his build on UTUBE).
If you have a bench grinder look at the multitool grinder attachment 2x36 @ $215.95 or 2x48 @ $349.00.
or
Kalamazoo 1x42 1/3 hp $330.00
Kalamazoo 2x48 1/2 hp $509.00
/ 2"X48" belt grinder #14
Just wondering if anybody has tried to smelt old aluminum metal to cast the big aluminum pullies. It is something I have thought about, but been afraid to try. I have a buddy that cast small aluminum parts. He uses old transmission cases or other busted parts and melts them in a homemade forge. He then uses some sort of green sand to make his molds.
/ 2"X48" belt grinder #15
Look on YouTube for a man called mrpete222. He recently made a video about fixing up a belt sander. And he has many videos of casting parts from aluminum, including wheels for a belt sander.
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A63111)
THIS WILL BE A...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
John Deere ZTrak Pro Series Z994R Operators Manual (A63117)
John Deere ZTrak...
Geringhoff John Deere Adapter Kit (A63117)
Geringhoff John...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
2018 INTERNATIONAL LT625 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 INTERNATIONAL...
