2 vs 4wd
/ 2 vs 4wd #21
I have always had 2wd tractors. I was loaned a 4wd once when my 5005 was in for warranty work. I loved it for pulling. But as far as loader work, get the bigger tractor. You will need the horses and hydraulics. With a loader, I would suggest the first addon being a lot wider front wheel/tire combo. 1st winter I had my 5005, I yanked the 7.5x16 wheels off the front and put on a set of 10.00x16 from an old JD 4320 we had. The bolt pattern was the same and they really helped in wet conditions with a bale of hay on each end. By the way, I am up here in East Texas so I probably see a little more of the wet stuff than you do. But it does cut down on rutting in the pasture with the wider tire. Only time I wanted 4wd was when I was pulling a 6 1/2' offset disc.
Ford F350 (A64127)
Ford F350 (A64127)
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
2021 Case IH 540 Steieger (A66285)
2021 Case IH 540...
2016 Jeep Patriot Sport SUV. (A64557)
2016 Jeep Patriot...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
NorTrac Rake (A64127)
