2 Stage Snowblower on a Gravel Drive (How To)
   / 2 Stage Snowblower on a Gravel Drive (How To) #11
I am confused the title is about a snowblower, but the video is about a plow ...
   / 2 Stage Snowblower on a Gravel Drive (How To) #14
I usually just use front blade until I've got an icebase before using blower.
   / 2 Stage Snowblower on a Gravel Drive (How To) #15
No matter what skid shoes you use it still disturbs gravel. That's why i put wheels on all my snowblowers. That includes 3pt snowblower. Keeps constant 2" space above ground and you can change it by tilting blower edge
I have done ths by mounting trailer tongue jacks on my snowblower. I can adjust the bottom edge as close or high as needed. Works great to lower over pavement, or raise blower over gravel. Jon
   / 2 Stage Snowblower on a Gravel Drive (How To) #16
I no longer use a blower. It was slow - took 3 1/2 to 4 hours to clear driveway, mailbox area and yard. Now I have a bigger tractor and use a HD rear blade. It now takes 1.5 hours to do the exact same job.
When I did use the blower. I had two "skids" made. 10" wide by 18" long. They worked well even when the gravel wasn't frozen up - hard as a rock. They kept the front lip of the blower about 1.5" up off the gravel surface.
Without the two skids - it was a REAL gravel chucking machine.
   / 2 Stage Snowblower on a Gravel Drive (How To) #17
I use a blade on FEL until I get a snow/ice surface with no gravel. Then snowblower works great, it is so fast with a pull type snowblower. I then use blade between buildings/cars where I can't shoot the snow anywhere.
2021 Ford F-150XL (A57148)
2021 Ford F-150XL...
Grecer Food Trailer (A55973)
Grecer Food...
LOT OF SHOVELS (A52708)
LOT OF SHOVELS...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
2020 KUBOTA RTV...
