2 Stage Snowblower on a Gravel Drive (How To)
   / 2 Stage Snowblower on a Gravel Drive (How To) #11
I am confused the title is about a snowblower, but the video is about a plow ...
   / 2 Stage Snowblower on a Gravel Drive (How To) #14
I usually just use front blade until I've got an icebase before using blower.
   / 2 Stage Snowblower on a Gravel Drive (How To) #15
No matter what skid shoes you use it still disturbs gravel. That's why i put wheels on all my snowblowers. That includes 3pt snowblower. Keeps constant 2" space above ground and you can change it by tilting blower edge
I have done ths by mounting trailer tongue jacks on my snowblower. I can adjust the bottom edge as close or high as needed. Works great to lower over pavement, or raise blower over gravel. Jon
   / 2 Stage Snowblower on a Gravel Drive (How To) #16
I no longer use a blower. It was slow - took 3 1/2 to 4 hours to clear driveway, mailbox area and yard. Now I have a bigger tractor and use a HD rear blade. It now takes 1.5 hours to do the exact same job.
When I did use the blower. I had two "skids" made. 10" wide by 18" long. They worked well even when the gravel wasn't frozen up - hard as a rock. They kept the front lip of the blower about 1.5" up off the gravel surface.
Without the two skids - it was a REAL gravel chucking machine.
   / 2 Stage Snowblower on a Gravel Drive (How To) #17
I use a blade on FEL until I get a snow/ice surface with no gravel. Then snowblower works great, it is so fast with a pull type snowblower. I then use blade between buildings/cars where I can't shoot the snow anywhere.
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
2005 Jeep Wrangler 4X4 SUV (A56859)
2005 Jeep Wrangler...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2006 Chevrolet Impala Sedan (A54815)
2006 Chevrolet...
2006 Wells Cargo 16ft T/A Enclosed Cargo Trailer (A55973)
2006 Wells Cargo...
22167 (A56859)
22167 (A56859)
