2 speed or 4 speed?
/ 2 speed or 4 speed? #1
dharrill
Claremont, NC
troy bilt horse tiller
I have a horse SN 663626, trying to figure out where I can get a manual for it or what year it is. Also is it a 2 speed or 4 speed. It has a high and low with forward and reverse. So would that make it a 4 speed.
/ 2 speed or 4 speed? #2
I have a 4 speed horse. It has a double pulley on the engine shaft and a double pulley on the transmission shaft. It also has a SINGLE belt between the two. The 4 speed comes in by changing the belt from one set of pulley grooves to the other set, front to back or back to front. The pulleys (or sheaves) are slightly different sizes in the groves thus when combined with the high/low speed shifter gives you 2 speeds for each belt position-----total 4 speeds. I have mine in the lower speed position and have never changed it since we bought the tiller in I believe 1976. (except to replace the belt) I think that the older 2 speed Troy-Bilts used 2 belts on matching sized pulleys, but I'm not sure if I'm remembering that correctly.
See if this link works for the manual.
http://www.troybilt.com/webapp/wcs/...ngId=-1&modelNumber=horse&serialNumber=663626
Paul
CRATE OF MISC ELECTRICAL WIRING (A67714)
CRATE OF MISC...
PORTA POTTY (A68842)
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2014 FREIGHTLINER CASCADIA (A67714)
2014 FREIGHTLINER...
2016 KUBOTA SVL75-2 SKID STEER (A65056)
2016 KUBOTA...
