2 speed or 4 speed?
/ 2 speed or 4 speed? #1
dharrill
Claremont, NC
troy bilt horse tiller
I have a horse SN 663626, trying to figure out where I can get a manual for it or what year it is. Also is it a 2 speed or 4 speed. It has a high and low with forward and reverse. So would that make it a 4 speed.
/ 2 speed or 4 speed? #2
I have a 4 speed horse. It has a double pulley on the engine shaft and a double pulley on the transmission shaft. It also has a SINGLE belt between the two. The 4 speed comes in by changing the belt from one set of pulley grooves to the other set, front to back or back to front. The pulleys (or sheaves) are slightly different sizes in the groves thus when combined with the high/low speed shifter gives you 2 speeds for each belt position-----total 4 speeds. I have mine in the lower speed position and have never changed it since we bought the tiller in I believe 1976. (except to replace the belt) I think that the older 2 speed Troy-Bilts used 2 belts on matching sized pulleys, but I'm not sure if I'm remembering that correctly.
See if this link works for the manual.
http://www.troybilt.com/webapp/wcs/...ngId=-1&modelNumber=horse&serialNumber=663626
Paul
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2015 ABU TRAILER 14 FOOT UTILITY TRAILER (A65643)
2015 ABU TRAILER...
Asphalt Melter (A61572)
Asphalt Melter...
2017 Chevrolet Sonic Hatchback (A61574)
2017 Chevrolet...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2011 Nissan Juke AWD SUV (A61574)
2011 Nissan Juke...
