2" receiver to cat 1 3 pt hitch
   / 2" receiver to cat 1 3 pt hitch #1
horseman1
Colorado
JD 2210,Farmall M, Craftsman GT and LT
2\" receiver to cat 1 3 pt hitch
I saw one of these in the Northern Tools catalog and have started welding it up. I would like to know of anyone can tell me the appropriate distance between the lift arm pins? I'm guessing that 26" would be OK. Any problems with that? I've made quite a few attachments for a sleeve hitch on the garden tractor, but this is my first project for the 3pt hitch on the JD 2210. It appears that there is some leeway, since the lift arms swing some, but I just wanted to check.
Thanks,
Kurt
   / 2" receiver to cat 1 3 pt hitch #2
Re: 2\" receiver to cat 1 3 pt hitch
I think 26" is the "standard" size. You can read more about the different hitch categories here.
Thanks a lot. I measured my box blade to get the 26" figure.
   / 2" receiver to cat 1 3 pt hitch #4
Or you can click here TractorSmart.com and read all about 3pt hitches. At the bottom of the page are the dimensions for the height between lift pins and top link and the lift arm spread for all categories of hitches.
Mad,
That site was just what I was looking for, 18" to the top link. Excellent. I plan on putting removable forks on the bottom of this thing too for some light lifting. I'll post a picture when I'm finished if it isnt too embarassing! Thanks again,
Kurt
   / 2" receiver to cat 1 3 pt hitch #6
Yep.. 26" is good for cat 1.
I've made a few things and originally started out by building off an existing cat 1 drawbar.
Soundguy
   / 2" receiver to cat 1 3 pt hitch #7
A handful of Cat 1 implements litter my backyard. For no apparent good reason, not all conform to the Cat 1 standard dimentions. Building your own 3PH frame to the standard is a good idea, but if the dimentions are a little off, it probably won't make too much difference.
OkieG
   / 2" receiver to cat 1 3 pt hitch #8
You've got to keep in mind that places like TSC sell 4 'apparently' cat 1 type of implement.
The cat 1 pinned with cat 0 spacings.
The cat 1 pinned X series of implements for the SCUT like BX tractors..
The true cat 1 spaced and pinned.
And the cat2 spaced but cat 1 pinned things.. like bale spears.. with the warning that you need a heavy tractor to use it.. etc.
That gives you a huge range of setups. Also.. I've seen lots of things an 'easyhitch' won't work on.. the 3pt spreaders come to mind..
Soundguy
   / 2" receiver to cat 1 3 pt hitch #9
I understand what you are saying. The first thing that came to my mind was just lax/sloppy adherence to the Cat 1 standard.
OkieG
   / 2" receiver to cat 1 3 pt hitch #10
I'me sure there is plenty of that as well.
Soundguy
Well, thanks to you all, mine complies /forums/images/graemlins/smile.gif. I finshed tonight and here's the picture.
   / 2" receiver to cat 1 3 pt hitch #12
Hey, that looks pretty good. Simple straight-forward design, quality work and nice color too.
Cliff
Thanks Cliff,
It took me a while since I grind better than I weld /forums/images/graemlins/smile.gif. The color match is pretty good with the JD 2210. Since I expect to use this for light duty, I didnt put in the usual angle pieces from the lift pins to the top link.
The next project will be some forks. Gotta start out slow and work my way up /forums/images/graemlins/smile.gif.The last thing I want is to work myself out of a job!
Kurt
   / 2" receiver to cat 1 3 pt hitch #14
<font color="blue"> The last thing I want is to work myself out of a job!
</font>
Good luck. Hasn't happened here yet.
OkieG
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2015 Ford Transit Connect Passenger Van (A59230)
2015 Ford Transit...
John Deere 6120M (A57148)
John Deere 6120M...
2020 Dodge Charger Sedan (A59231)
2020 Dodge Charger...
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
