2 properties
/ 2 properties #31
radioman said:
Well - the BX will run nearly all day on a tank. ;)
Point is what will take a BX all day will take a 2x200/B half a day. The larger machine will burn a lot less in the half a day than the smaller in a full day.
/ 2 properties #32
To the OP...I still don't understand WHY you want to drive your tractor that distance to/from house/property? It seems to me you are going to end up with a tractor that is not ideally suited for either location. It'll be too big for the current house, and you'll be kicking yourself later for not going bigger at the new property.
For 0.4 acre or whatever it is, I would keep the current riding mower or replace it with a cheap used one to get by until you get moved out.
2018 ALLMAND MP40-8BI-PORTABLE DIESEL GENERATOR (A59823)
2018 ALLMAND...
2020 Case 5550 Trident (A61307)
2020 Case 5550...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
Zero Turn Mower (A59231)
Zero Turn Mower...
TANK MANIFOLD (A55745)
