2 Inch Receiver On PT422 probably 425
   / 2 Inch Receiver On PT422 probably 425 #21
These hitches are very handy two weeks ago I orderd a two inch hitch with a 48 inch reciever tube along with a ripper claw. I am working on a ripper for use in digging holes pulling up rocks and tree stumps.
   / 2 Inch Receiver On PT422 probably 425 #22
Nice job there Bob, wish I had a welder and the ability to weld.
I plan to order an electric winch for mine and other interchangeable attachments for it. Since I don't have a welder, I plan to attach everything to my forks. Hopefully a few bolts on and off.
   / 2 Inch Receiver On PT422 probably 425 #23
Sorry Bob,
wasn’t trying to hone in on your thread. I’ll put this under a separate title.
BarryH, I have a welder, I wish I could weld. I just read the book.
Hopefully this is my last set of pictures for this attachment. I expect everybody is getting tired of the updates.
I noticed a little tilt. Other than that it looks good. I had some friends stand on it to demonstrate its strength. Their total weight is about 330 pounds. I cut their heads off because that would have been too much weight. I also put my 250 pounds on one side (not at the same time as theirs) and there was very little give.
Thanks for all of the interest, support, and advice. This make for a much better attachment.
Bob Rip
   / 2 Inch Receiver On PT422 probably 425 #25
Looks strong enough to me good job.
Is that your Trans in the garage or is that a Firebird? I had the 99 Trans- AM pewter, with black convertable top. The wife had a 99 Firebird same color as the one in your garage. Loved that car.
It belongs to a nephew's friend. I am letting him use my lift and tools to change the exhaust system.
I think you could be this 2 inch receiver with bolts instead of welding.
Bob Rip
I figured it is time for an update. I added two more bolts near the middle of the angle irons. This is probably not needed, but it was easy. Notice that they are installed where the metal web is located, not where Power Trac had cut out slots. I think this is important. I am now comfortable with this change and will probably not need to take it off very often, so a couple of extra bolts is no big deal.
Bob Rip
I installed the carrier and bounced up and down on it with my body weight. The tires flexed, but nothing else did. The carrier is designed for 500 pounds. I don't plan to carry that much on it. I think this will be useful when I move firewood around the property. I can put some in the bucket and some on the carrier. It also could be used to carry an extra attachment or other stuff to the back of the propery.
Bob Rip
Since the pin receiver is covered with the 2 inch receiver, I decided to make a 2 inch receiver to pin receiver adapter. Here it is shown ready to paint. I will use this to pull a small trailer or fertilizer.
Bob Rip
I did an untentional modification to my bumper today when a tree got between the rear wheel and the bumper. I ended up breaking off one end of the bumper. The metal was not damaged and I guess. I should be happy because that was the idea. The wood bumper breaks and not the metal. I have made a new wooden piece and it is only 29 inches long so it only sticks out 3.5 inches past the PT body. The old one stuck out eleven inches, even with the wheel. I have attached a picture of the broken bumper. The new one is in the paint drying booth which looks a lot like my garage. Lession - Don't stick things out to far or they can get broken off.
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
2012 John Deere TX Gator Utility Cart (A56857)
2012 John Deere TX...
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
John Deere 5105M (A53317)
John Deere 5105M...
