3-Point Hitch 2 bottom plow
/ 2 bottom plow #2
Yes
But that depends on how good you want the plowing job to be, and what tranny and tires you have on the 4310.
Tell us more....
/ 2 bottom plow #3
How much you plowing 4wd I presume? I used to pull a two bottom with my 4wd L2850 kind of comparable to a 4310 very slow going. Then I got a old L4150 much easier and did a better job in my experience
/ 2 bottom plow
It’s an ePowrReverser with ag tires. Tires are not filled. Has a 300c loader.
/ 2 bottom plow #5
Should work if you can get the tire spacing right.
What plow you have in mind? Pic would help. There should be some good adjustments to get it to plow good.
/ 2 bottom plow #6
I pull a 4 bottom with trips regularly with a 4630.
/ 2 bottom plow #7
Depend's on soil so your guess is better than mine. No way 30 horse pressure can pull 2 bottoms here but less than 30 miles in one direction and 40 in another they do it all the time. You might get a better idea by giving it a try.
/ 2 bottom plow #8
John Deere 4310 Weight
2,600 lbs
1179 kg (2WD)
2,900 lbs
1315 kg (4WD)
Max Drawbar:562 lbs
254 kg
Max front axle:1,588 lbs
720 kg
Max rear axle:4,410 lbs
2000 kg
Dimensions
Wheelbase:68 inches
172 cm
Length:117 inches
297 cm
Width:50 inches
127 cm
Ground clearance:13.4 inches
34 cm
/ 2 bottom plow #9
If your Deere 4310 has 2-WD it will pull a two-bottom moldboard plow of 12" width through reasonably moist soil.
If your Deere 4310 has 4-WD it will pull a two-bottom moldboard plow of 12", or 14" width through anything.
If your Deere 4310 has 4-WD it will pull a three-bottom moldboard plow of 12" width through reasonably moist soil.
A 16" width plow moves almost twice the dirt, relative to a 12" plow.
/ 2 bottom plow #10
According to Tractordata a JD 4630 has 127 db HP & weighes over 16,000#s I've pulled 6X14 moldboard with my JD 4255 rated at 112 db HP & weighes over 12,000#s BUUT both these models are rowcrop tractors while OP's tractor is a much smaller frame utility model
I'll wager a JD 4310 MFWD can't pull a 3 bottom moldboard in my soil type.
/ 2 bottom plow #11
Yes. Some posts, while true, sow confusion rather than light.
John Deere 4630​
Dimensions
Wheelbase:112.65 inches
286 cm
Length:171.2 inches
434 cm
Height (steering wheel):93.6 inches
237 cm
Height (cab):116.9 inches
296 cm
Operating weight:16250 lbs
7371 kg
/ 2 bottom plow #12
Can you expound on that?
/ 2 bottom plow #13
depended on your soil, depth of plowing and spacing of the plow… i have a 60hp MF and with a 12inch two furrow bottom plow i was going as deep as i could and in some spots with i had trouble and some not at all …
/ 2 bottom plow #14
Agree, as same with my 4300.
And all depends on the depth one is trying to moldboard plow. Or it be sod ground, old pasture ground, clay (blue, red, ??), sandy loam, wet, dry, etc, etc.
So many variables to put into the equation.
/ 2 bottom plow #16
I'm sitting with sheer anticipation for that explanation. Moldboard wings are the same size for different point size. So the extra 4'' of 16'' point size would have to be moving same amount of soil as the 1st 12''. Very interesting concept that I would like to have explained to this forum
/ 2 bottom plow #17
Could have been a typo like someone:unsure: that said "Yes. Some posts, while true, sow confusion rather than light." But meant to say,,,,,Some posts are true and some sow confusion. :ROFLMAO:
/ 2 bottom plow #18
Guess it depends on the bottom, my plows the moldboard is the width of furrow and point is only part the width of the furrow.
The double comment stems from the old rule of thumb to plow only as deep as half the width of the bottom, while one 16" not quite double one 12", here is the theory:
12" = 6" deep 6x12= 72 square inches per bottom
16" = 8" deep 8x16 = 128 square inches per bottom.
/ 2 bottom plow #20
31.2 Horsepower
No, not in unbroken soil
In broken soil yah, but you need more Ooomph than that in virgin land.
I dropped a 16" two bottom in my unbroken soil last fall. It was a lot of effort for my 47 HP DK4710 to pull it. There were times it stopped my forward motion entirely, necessitating that I lift it.
LANDPRIDE FDR1648 - 48" FINISH MOWER (A64280)
LANDPRIDE FDR1648...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
2015 Ford Taurus AWD Sedan (A61574)
2015 Ford Taurus...
(4) RUBBER TIRE LOADER TIRES (A62613)
(4) RUBBER TIRE...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64280)
KNOW BEFORE YOU...
