1st report on FEL edge guard
   / 1st report on FEL edge guard #11
TresCrows
Finally got around to buy and install a rubber edge on my snow blade. Purchased it at this place Anglos .
Attached is a picture of the rubber edge before I installed it.
   / 1st report on FEL edge guard #12
Here is a picture of the rubber edge installed.
Waiting for some snow to try it out. /forums/images/graemlins/grin.gif
   / 1st report on FEL edge guard #13
Is that rubber edge slotted?
It would sure help in compensating for wear and tear.
   / 1st report on FEL edge guard #14
tomnky
No, I have to drill new holes to lower it. I did see a site that had them slotted. But they did not have the correct pattern for the Curtis blade.
   / 1st report on FEL edge guard #15
Thanks Ron,
I was curious as I first ordered My BX2763 Bade back in September and did order a squeegee at the same time , which was back-ordered .
They told me today I should have it by Mid-January , So naturally I was curious.
   / 1st report on FEL edge guard #16
That material looks very much like the horse stall mats I see at the stores. It is a thick, heavy, dense rubber mat. It would be very easy to buy a sheet of the stuff and cut it for use as edge guards. I almost did that but found the plastic pieces I installed instead. Looks like it will work great. Never thought about it to much but my plastic edge might still scrape an asphalt drive but that rubber would surely not. J
   / 1st report on FEL edge guard #17
TresCrows
It appears to be very heavy conveyor belting 1 1/4" thick. The place were I bought it from claims it's great for gravel drives.
   / 1st report on FEL edge guard #18
Got to try out my new rubber blade edge Christmas day. It worked great except that rubber bent back about 45 degrees. /forums/images/graemlins/frown.gif
I took a picture yesterday. The rubber had returned back to some of its original strait position. See attached picture.
The edge works great on my paver brick walkways. /forums/images/graemlins/smile.gif
   / 1st report on FEL edge guard #19
Remounted the rubber in front of the original blade edge. This should provide some support for the rubber. Added a ¼” X 2” bar across front of the rubber edge for added support.
I am waiting for some more snow to try it out again. /forums/images/graemlins/wink.gif
It rained all day yesterday. /forums/images/graemlins/ooo.gif
Back to no snow in Southeastern Michigan again. /forums/images/graemlins/frown.gif
   / 1st report on FEL edge guard #20
Ron I think that you are on the right track with your latest modification. /forums/images/graemlins/wink.gif Giving the belting some extra support should do the trick for you.
KBH 25T Tender (A56438)
KBH 25T Tender...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
