1st report on FEL edge guard
   / 1st report on FEL edge guard #11
TresCrows
Finally got around to buy and install a rubber edge on my snow blade. Purchased it at this place Anglos .
Attached is a picture of the rubber edge before I installed it.
   / 1st report on FEL edge guard #12
Here is a picture of the rubber edge installed.
Waiting for some snow to try it out. /forums/images/graemlins/grin.gif
   / 1st report on FEL edge guard #13
Is that rubber edge slotted?
It would sure help in compensating for wear and tear.
   / 1st report on FEL edge guard #14
tomnky
No, I have to drill new holes to lower it. I did see a site that had them slotted. But they did not have the correct pattern for the Curtis blade.
   / 1st report on FEL edge guard #15
Thanks Ron,
I was curious as I first ordered My BX2763 Bade back in September and did order a squeegee at the same time , which was back-ordered .
They told me today I should have it by Mid-January , So naturally I was curious.
   / 1st report on FEL edge guard #16
That material looks very much like the horse stall mats I see at the stores. It is a thick, heavy, dense rubber mat. It would be very easy to buy a sheet of the stuff and cut it for use as edge guards. I almost did that but found the plastic pieces I installed instead. Looks like it will work great. Never thought about it to much but my plastic edge might still scrape an asphalt drive but that rubber would surely not. J
   / 1st report on FEL edge guard #17
TresCrows
It appears to be very heavy conveyor belting 1 1/4" thick. The place were I bought it from claims it's great for gravel drives.
   / 1st report on FEL edge guard #18
Got to try out my new rubber blade edge Christmas day. It worked great except that rubber bent back about 45 degrees. /forums/images/graemlins/frown.gif
I took a picture yesterday. The rubber had returned back to some of its original strait position. See attached picture.
The edge works great on my paver brick walkways. /forums/images/graemlins/smile.gif
   / 1st report on FEL edge guard #19
Remounted the rubber in front of the original blade edge. This should provide some support for the rubber. Added a ¼” X 2” bar across front of the rubber edge for added support.
I am waiting for some more snow to try it out again. /forums/images/graemlins/wink.gif
It rained all day yesterday. /forums/images/graemlins/ooo.gif
Back to no snow in Southeastern Michigan again. /forums/images/graemlins/frown.gif
   / 1st report on FEL edge guard #20
Ron I think that you are on the right track with your latest modification. /forums/images/graemlins/wink.gif Giving the belting some extra support should do the trick for you.
John Deere 1025R Sub-Compact Tractor Mower (A56857)
John Deere 1025R...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2018 FREIGHTLINER...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2008 Jeep Wrangler 4X4 SUV (A56859)
2008 Jeep Wrangler...
TANK MANIFOLD (A55745)
