Oil & Fuel 1st Oil Change on BX2660
   / 1st Oil Change on BX2660 #31
The bolt I listed (1/4-20 x1-1/4) is what's listed in the manual as the right bolt. I guess I'm gonna be taking it apart. Thanks for the input guys.
Hemps
   / 1st Oil Change on BX2660 #32
Hemps
On my model they use bolts of the same size for the auger and impeller but they are different hardness with the impeller bolt being the hardest one. That's the only reason I mentioned it. At any rate you might consider starting a new thread since your question was buried in a discussion about oil which might not get that many reads. Good luck and I hope you find what's ailing your blower before the next 30" snow comes rolling in. I used a loader for 11 years before getting the blower this year so I know how you feel at having to go back.
Sent from my iPad using TractorByNet
   / 1st Oil Change on BX2660 #33
getting back to the impeller shear bolts....make sure that augers are set up properly. On mine the left and right are 180 degrees apart in rotation. Should be covered in the manual and there maybe a sticker on the blower to that effect.
   / 1st Oil Change on BX2660 #34
Thanks to both you and Sandyc. The position of the augers makes sense, but no mention of that in the manual I have. Will check the bolt hardness but also no mention in the manual.. New to the process, so didn't know how to starta thread and get it to the right audience. Pick the one because it was about the B2660.
New/Unused CFG Industrial NT18K Mini Excavator (A57453)
New/Unused CFG...
2020 HINO 268 26FT NON CDL BOX TRUCK (A59575)
2020 HINO 268 26FT...
2014 HYUNDAI 53FT DRY VAN TRAILER (A59575)
2014 HYUNDAI 53FT...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A56859)
2014 Glasstream...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
