1st gear
/ 1st gear #1
offshorerivas
la blanca,tx
jd2040
my tractor will not engage 1st gear but the rest will. to fix will it have to be split . 1st thread i meant frontend loader 143.
thanks
/ 1st gear #2
:welcome: to TBN
You can edit and/or reply to the first post.. no need to make up another new post..
Hope someone who can decipher the 1st gear problem will chime in with some help. Seems more information about just what is happening would be helpful.
cheers
/ 1st gear #3
Most likely it will need to be split. It is possible the problem would be under the shift cover or under the rockshaft housing. Does the shift lever go into the position for 1st gear and tractor won't move, or will he lever refuse to go into the 1st position? Is the serial number above or below 350,000? If above 350,000 it may have a synchronized transmission. Either way, I would remove the shift cover and rockshaft housing and see if you can identify the problem from there. It could be there is something broken that is blocking the shifter from moving. Those transmissions were pretty bulletproof. I don't recall ever having one that would not engage 1st gear.
/ 1st gear #5
my tractor will not engage 1st gear but the rest will. to fix will it have to be split . 1st thread i meant frontend loader 143 thanks
Are you positive 1st gear is the only accessible gear? will it go in 5th gear? My guess shifting problem is metal tab broke off shift rail. Remove gearshift cover for a visual inspection.
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
Mini Bucket Excavator Attachment (A61572)
Mini Bucket...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
John Deere 5045E for sale
John Deere 5045E...
KMC 4R ROLLING CULTIVATOR (A63291)
KMC 4R ROLLING...
