1st gear
/ 1st gear #1
offshorerivas
la blanca,tx
jd2040
my tractor will not engage 1st gear but the rest will. to fix will it have to be split . 1st thread i meant frontend loader 143.
thanks
/ 1st gear #2
:welcome: to TBN
You can edit and/or reply to the first post.. no need to make up another new post..
Hope someone who can decipher the 1st gear problem will chime in with some help. Seems more information about just what is happening would be helpful.
cheers
/ 1st gear #3
Most likely it will need to be split. It is possible the problem would be under the shift cover or under the rockshaft housing. Does the shift lever go into the position for 1st gear and tractor won't move, or will he lever refuse to go into the 1st position? Is the serial number above or below 350,000? If above 350,000 it may have a synchronized transmission. Either way, I would remove the shift cover and rockshaft housing and see if you can identify the problem from there. It could be there is something broken that is blocking the shifter from moving. Those transmissions were pretty bulletproof. I don't recall ever having one that would not engage 1st gear.
/ 1st gear #5
my tractor will not engage 1st gear but the rest will. to fix will it have to be split . 1st thread i meant frontend loader 143 thanks
Are you positive 1st gear is the only accessible gear? will it go in 5th gear? My guess shifting problem is metal tab broke off shift rail. Remove gearshift cover for a visual inspection.
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2016 CHEVROLET TAHOE (A66091)
2016 CHEVROLET...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
2001 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2001 FORD F150...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
