Spades 5310
- Joined
- Dec 10, 2024
- Messages
- 3
- Tractor
- JD 5310
This will be a long one, Apologies!!!
Afternoon, as the title states I am having issues with my 5310. It started around a month ago. Ran fine then would turnover but not start 2 weeks later. Trouble shot the whole fuel system and fuses etc. After doing some more research, I found the Temp Sensor for cold start trouble shooting and I thought that was the issue. Replaced it with JD OEM, ran great for 5 or 6 hrs on Nov 26th. Tried to start it the next day and it would turn over but not fire. I started back at square one with the fuel system etc. After draining off the fuel bowl for the um-teenth time, replacing fuel line (prior owner had it cobb-jobbed with rubber fuel hose because it was broken) from filter to injection pump it fired and I was able to move it from the field to my shop. No start the next day.... Once again, I drained the fuel and cleaned the bottom of the tank with a brush on a yard stick as there was a lot of nastiness in the bottom. Removed the fuel filter bowl and cleaned it thoroughly along with putting on a new filter. Removed main fuel line from tank to filter, blew that out and it was clear. I then refilled the tank (fresh fuel:15gal), bled all the lines and had it running for about a minute before it died out. Replaced the hand primer when my father in-law who was here this past weekend was helping me troubleshoot everything I already did again! We were able to get it running. It ran fine, shut off and fired right back up like there were no issues at all. Went out the next morning to finish my field and no start once again... We have no idea why it started/ran fine and now it wont.
I have been racking my head with everything. Checking connections ALL fuses, replaced fuel shutoff relay, replaced fuel line rubber gromets. Checked electrical connections for continuity. Injection pump has power and solenoid clicks, I can feel all the relays behind dash click. Right now I think I have it narrowed down the the actual injection pump. I have fuel to it and no air coming out. If I remove the return line on top and pump the hand primer fuel comes out. However, I do not have fuel coming out of the fuel injector lines themselves. I even removed plug to the injection port gear and it is spinning when it turns over.
Thoughts on any of this? Is there a way to remove the injection pump and put some sort of cleaner in it to make sure its not clogged?
