1998 JD 4100 HST won't move
/ 1998 JD 4100 HST won't move #1
feh3rd
1998 JD 4100 HST Tractor
My 1998 JD 4100 HST won't go into reverse or go forward. The shift lever between low and high now just slides back and forth and won't click into either position. I was moving some dirt around and stopped to back up and tractor wouldn't move either forwards or reverse. Tractor was just serviced by dealer and hydraulic fluid is good. Tractor has 550 hours on it. Any advice would be greatly appreciated. Thanks.
/ 1998 JD 4100 HST won't move #2
Sorry, I don't know your tractor model well but if there are any linkage connections they would need to be checked to see if anything has come apart. If the shifter is directly connected to a shaft that runs into the gear box then the only thing you can check is that the connection there is rotating the shaft. If it is, then the problem is likely internal and time to call a specialist.
Thanks, I'll do some snooping around to see what I can find out.
/ 1998 JD 4100 HST won't move #4
Check your private messages
