1996 Kioti LK3054.
/ 1996 Kioti LK3054. #1
Rodgerd
Mars, Pa
LK3054 Kioti
I have an early 1996 LK 3054 Kioti. The front bevel pinion shaft is very small and broken. It is about 5/8 to 3/4 inch in diameter. This drives the 4 wheel drive which is inop. Seems really under engineered. Anyone know a cure? Thank You for any help you can provide. Rodgerd
/ 1996 Kioti LK3054. #2
The only practical "cure" to making the 4 WD operable again is to replace it with another OEM shaft. It would take a considerable amount of re-engineering to adapt a "heavier" pinion shaft arrangement. I have read a little about having hard parts cryogenically treated for increased durability...might give that a look. Just don't know of a cost effective way to upgrade the front end to heavier components, or if what appears to be an undersized shaft is even an issue that might recur/ be a common failure to that machine......could have been a one time incident??
Thank You so much for the reply. The shaft was broken when I bought it so I don't know what it took to break it. I discovered the housing was in need of repair as well so maybe that caused it I ordered the part thru a dealer back in June, and when it came in it was about twice the diameter. They said that was what it called for. Of course it wouldn't work but they couldn't tell me how to get an original one because there parts listing didn't give any diameters. I had given them the serial number. (526500885) This small parts runs right and left axels about 1 1/2 inches in diameter. I was told Kioti was expanding their parts base but don't know if that will help. They said they took pictures and sent them to the Kioti rep but here I am with the tractor still in pieces.
/ 1996 Kioti LK3054. #4
When you look at Kioti's online parts diagrams, it does appear to give 2 different pinion shaft numbers. If you look at the differential diagram it lists the pinion shaft as #35250-43210. If you look at the bevel pinion shaft diagram it list the pinion shaft as # T2185-43212....could this be the confusion in which parts the dealer has ordered?
Thanks again, The part that was too big was T-2185-43212 Rodger
/ 1996 Kioti LK3054. #6
Meant to mention that these were both listed under "front axle" components. Wanted to clarify that these were both front end pinions with different numbers, not one front and one rear.
/ 1996 Kioti LK3054. #7
If you go to MIE, they will have online parts/diagrams, etc. Ask them what you need based on your search- they should be able to get you going.
OEM Parts
Darryl, I wanted to let you know that dealing with Michigan Iron was a great experience. They said it might take 3 to 4 weeks to get the part I needed as it was out of stock and it was at my door in 2 weeks. Great to be able to get the tractor back together. Thank You so much for all your help. Rodger Hats off to Bob in parts at Michigan Iron and Equipment. Thanks
/ 1996 Kioti LK3054. #9
So what exactly was the outcome?:confused2: MIE got you the correct part? What caused the break?
Yes, MIE got me the right part. Part was broken when I got the tractor.
/ 1996 Kioti LK3054. #11
Forgot you said it was broken when you got it. Any thoughts from MIE or you as to what caused it to break?
I believe the early ones were under engineered as the newer (wrong) part was way bigger. I was told that is a complete axle change to improve what I got. I discovered the axle housing was broken from the mount and had a hole in it as well and full of water, I had it repaired at a local machine shop. Maybe that caused the breaking. Before I got it ,it was used in a junkyard with really rough terrain. I'm hoping I have better luck with it. I'm just planning on using it around the house so maybe it will hold up, if not I not I know where to get the parts. I waited like 4 months at the local Kioti dealer telling me they couldn't get the original part. That is why I'm so thankful for all the help. Thank You Rodgerd
/ 1996 Kioti LK3054. #13
Thanks for the details. Glad to hear MIE was able to help- I've been buying items and maintenance parts from them for years and they are very accommodating.
Can you post some pics of the machine and any shots of the repair you might have?
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
2017 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2017 PETERBILT 579...
2021 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2021 Chevrolet...
1999 PETERBILT 379 ROAD TRACTOR (A65054)
1999 PETERBILT 379...
2011 18ft. Maxey Flatbed Utility Trailer (A64194)
2011 18ft. Maxey...
1989 CUTOM 15T-100 EQUIPMENT TRAILER (A66091)
1989 CUTOM 15T-100...
