1994 753c right motor issues
/ 1994 753c right motor issues #1
tkoser
2006 bs2230
OK made that crucial mistake of buying something from a family member on their word. Got home only to discover a huge hydraulic leak.
The right drive motor, as I sit on the loader has a leak. The leaks are at the two hex plugs on the face of the motor. I assume they are pressure relief. I took off both caps took out the springs taper caps and check them out. All ok. I replace the O rings on the caps and still leaks. I also notice that the right motor feathers in different then the left. It feathers in nice until about half of the stick movement then it moves quickly.
Things I have done and noticed
All hydraulics have plenty of power. Loader works great
left drive motor is good
Changed filters
no other leaks or issues
4,000 hrs
Re: 1994Bobcat 753c right motor issues
OK all need some help here. Cant use it as is. Do I need to replace the hydraulic motor
:confused2::confused2:
/ 1994 753c right motor issues #3
You might want to post your inquiry in the Bobcat construction equipment forum which deals with skid steer units. You will probably have better luck getting a reply.
