1992 L3450 jerky 3 point please help
/ 1992 L3450 jerky 3 point please help #1
david.phillips181
Hi there new to the site and looking for ideas on ajusting or fixing my 3 point. My 3 point goes up and down when unloaded just fine. The 3 point will hold weight in the up position all night without sinking. If you pull the depth control level quickly and stop the 3 point lifts without issue. If you go slowly with the attachment on it jerks the tractor all over the place. 650 hours service has been completed. I quickly played with the one adjustment on th3 3 point without luck
Any ideas??
I would like to add I just removed my front mount blower prior to noticing this problem. Is it possible teh loader valve has something to do with my problem?
/ 1992 L3450 jerky 3 point please help #3
Any chance the front mount blower was serving as ballast and it's the weight of the rear implement jerking the tractor around more so than the 3 point's performance? I guess that depends if you have a loader on there now.
I'm one stuck with the jerky L3400 3 pt valve, so I feel for you. Good luck.
i just bought the tractor. its a one owner used for snow only. in mint shape. It is only jerky when being slowy raised in one fuild motion. I agree the offset of the blower would help but I know it will still shake the crap out of the tractor
