1985 Ford 1710 Insight & Advice Needed.
/ 1985 Ford 1710 Insight & Advice Needed. #1
JeffRussell.org
Connersville, IN
1985 Ford 1710 4WD
Need to locate a replacement head or complete engine to repair or replace my Shibuara 3 cylinder diesel. I have been searching for quite some time, almost a year, with no luck. :confused:
So... anyone know of a source for a replacement head or engine? I have also been given serious thought to trying to locate a engine that could be swapped into this tractor. Anyone know of suitable engine to drop in, or have any experience in attempting to do such a swap?
The main use of the tractor is it's loader around the property, and maybe a couple hours a year to till the garden - so I would even consider a gas engine if I could find a suitable engine to swap in...
Any advice/insight would be greatly appreciated!
Jeff
/ 1985 Ford 1710 Insight & Advice Needed. #2
The 1720, both Ford, and later NH, was one of the most popular tractors they built in recent history. I don't know for sure, but it's possible there could be more parts available for it, if it will work for your 1710.
/ 1985 Ford 1710 Insight & Advice Needed. #3
CNH dealer can't get you your parts? Messicks can get you a complete head for $1911.11.
My local dealer can order me a new head for around that price, I just hate to spend so much on a 20+ year old tractor. The additional cost of rings, bearing, gaskets, etc would push the cost in the neighborhood of $3000 - and that is quite a sum for this age of tractor.
With the popularity of these little tractors, I have been very surprised that used parts and aftermarket parts are so hard to come by. I wonder if there is a source of information on what engines might interchange with this frame? I know there is information available for automobiles...
Any suggestions would be appreciated :confused:
/ 1985 Ford 1710 Insight & Advice Needed. #5
Can the head be fixed?
/ 1985 Ford 1710 Insight & Advice Needed. #6
These tractor just don't break much. I had one and I expect that most of them are still running and haven't created a supply of used heads. There are probably a few aroung though. Have you tried the lard salvage yards?
Andy
