1984 Ford 4610 fuse block
   / 1984 Ford 4610 fuse block #1
Lizer
Richland, MI
Ford 4610
I have an 84 Ford 4610 diesel. Does it have a fuse block? I am in the process of painting it and painted the fenders and reinstalled tonight. None of the lights worked but I was getting voltage to the plugs so figured it was a bad ground because of all the paint on the fenders. I ran a jumper ground wire from one of the lights to the frame and some of the lights came on. When I was testing the ground jumper with the headlights on the front of the fenders the ground made a spark and then I heard a little pop and all the lights went dead...even the backlighting for the instrument panel which was on up until this point.
Is there a fuse blown somewhere, or a fuse box? I can't find one anywhere. I looked behind the battery and didn't see anything.
//edit: I did find what looks like an inline fuse above the gas tank under the cowl but it's a tight reach in there. According to the schematic that's a 3 amp fuse, but I can't figure out who it comes apart and I don't want to break it forcing it. Anybody know how this comes apart?
   / 1984 Ford 4610 fuse block #2
On our 3910, its on the firewall by the fuel tank. It's like 3-4" square and might have a cover over it.
   / 1984 Ford 4610 fuse block #3
most likely its only going to have a relay in proximity to the switch behind the dash , That's how late 70's early 80's tractors I've dealt with are wired
Yeah there is no fuse block on this tractor. Digging into it more I found a 25 amp fuse on the light switch itself, and of course it was blown.
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
CATERPILLAR 279C SKID STEER (A52709)
CATERPILLAR 279C...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 Dodge Charger Passenger Car, VIN # 2C3CDXAT4FH817483 (A57453)
2015 Dodge Charger...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
