1984 Ford 4610 fuse block
   / 1984 Ford 4610 fuse block #1
Lizer
Richland, MI
Ford 4610
I have an 84 Ford 4610 diesel. Does it have a fuse block? I am in the process of painting it and painted the fenders and reinstalled tonight. None of the lights worked but I was getting voltage to the plugs so figured it was a bad ground because of all the paint on the fenders. I ran a jumper ground wire from one of the lights to the frame and some of the lights came on. When I was testing the ground jumper with the headlights on the front of the fenders the ground made a spark and then I heard a little pop and all the lights went dead...even the backlighting for the instrument panel which was on up until this point.
Is there a fuse blown somewhere, or a fuse box? I can't find one anywhere. I looked behind the battery and didn't see anything.
//edit: I did find what looks like an inline fuse above the gas tank under the cowl but it's a tight reach in there. According to the schematic that's a 3 amp fuse, but I can't figure out who it comes apart and I don't want to break it forcing it. Anybody know how this comes apart?
   / 1984 Ford 4610 fuse block #2
On our 3910, its on the firewall by the fuel tank. It's like 3-4" square and might have a cover over it.
   / 1984 Ford 4610 fuse block #3
most likely its only going to have a relay in proximity to the switch behind the dash , That's how late 70's early 80's tractors I've dealt with are wired
Yeah there is no fuse block on this tractor. Digging into it more I found a 25 amp fuse on the light switch itself, and of course it was blown.
2002 Ford F-650 Landscape Flatbed Truck (A56858)
2002 Ford F-650...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
2022 Ford Explorer 4WD SUV (A56859)
2022 Ford Explorer...
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
