1984 Ford 4610 fuse block
   / 1984 Ford 4610 fuse block #1
Lizer
Richland, MI
Ford 4610
I have an 84 Ford 4610 diesel. Does it have a fuse block? I am in the process of painting it and painted the fenders and reinstalled tonight. None of the lights worked but I was getting voltage to the plugs so figured it was a bad ground because of all the paint on the fenders. I ran a jumper ground wire from one of the lights to the frame and some of the lights came on. When I was testing the ground jumper with the headlights on the front of the fenders the ground made a spark and then I heard a little pop and all the lights went dead...even the backlighting for the instrument panel which was on up until this point.
Is there a fuse blown somewhere, or a fuse box? I can't find one anywhere. I looked behind the battery and didn't see anything.
//edit: I did find what looks like an inline fuse above the gas tank under the cowl but it's a tight reach in there. According to the schematic that's a 3 amp fuse, but I can't figure out who it comes apart and I don't want to break it forcing it. Anybody know how this comes apart?
   / 1984 Ford 4610 fuse block #2
On our 3910, its on the firewall by the fuel tank. It's like 3-4" square and might have a cover over it.
   / 1984 Ford 4610 fuse block #3
most likely its only going to have a relay in proximity to the switch behind the dash , That's how late 70's early 80's tractors I've dealt with are wired
Yeah there is no fuse block on this tractor. Digging into it more I found a 25 amp fuse on the light switch itself, and of course it was blown.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
