1981 John Deere 2040 with over heating problem
   / 1981 John Deere 2040 with over heating problem #21
Looks like I have the same problem, would it be possible to repair this without removing the entire column?
Thx
One can remove steering wheel then remove large nut then rotate shaft CCW & shaft with 2 valve bodies then shaft with bodies will come out of housing. With the aid of a good, long pick the six large o-rings can be R&R from each land. After R&R of o-rings reinstall shaft with valve bodies after applying hyd oil to exterior of valve bodies. If upon extended engine operation if one then detects heat & if o-rings were installed correctly then valve bodies are probably at fault. Valve bodies part # is AR81610 @ $1,409.43 each If valve bodies are removed from shaft be sure to record shim locations!!!!!
PALLET OF (2) HEATERS (A55745)
PALLET OF (2)...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
CATERPILLAR H90C HYD HAMMER (A52707)
CATERPILLAR H90C...
Hose Reel (A55787)
Hose Reel (A55787)
CASE 610 Sprayer System 2000 Gallons (A55315)
CASE 610 Sprayer...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
