1975 Ford 2000 Hydraulics Bleeding
/ 1975 Ford 2000 Hydraulics Bleeding #1
99FordStang
Ashford, CT
1975 Ford 2000 TLB
Can anyone help with bleeding instructions for Ford 2000 ? I had a hose go on the backhoe, refilled the fluid, and i apparently have a lot of air in the system because the loader now is having trouble. I have read 2 different opinions
1) No bleeding necessary because the air escapes out of the pump just use the hydraulics.
2) un screw the hard line going into the hyd pump and attach a hose to it back to the fill tank and run until smooth
/ 1975 Ford 2000 Hydraulics Bleeding #2
keep the sump full and just run all the cyls lock to lock several times and it WILL self bleed ...
2011 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2011 COMPTANK...
2012 ATLAS COPCO  AIR COMPRESSOR XAS 375 (INOPERABLE) (A68842)
2012 ATLAS COPCO...
3097 (A63117)
3097 (A63117)
AGrotk QA  Dozer Blade (A64912)
AGrotk QA Dozer...
2003 Chevrolet 3500 (A64911)
2003 Chevrolet...
2013 Ford Explorer SUV (A66738)
2013 Ford Explorer...
