1975 Ford 2000 Hydraulics Bleeding
   / 1975 Ford 2000 Hydraulics Bleeding #1
99FordStang
Ashford, CT
1975 Ford 2000 TLB
Can anyone help with bleeding instructions for Ford 2000 ? I had a hose go on the backhoe, refilled the fluid, and i apparently have a lot of air in the system because the loader now is having trouble. I have read 2 different opinions
1) No bleeding necessary because the air escapes out of the pump just use the hydraulics.
2) un screw the hard line going into the hyd pump and attach a hose to it back to the fill tank and run until smooth
   / 1975 Ford 2000 Hydraulics Bleeding #2
keep the sump full and just run all the cyls lock to lock several times and it WILL self bleed ...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2019 CATERPILLAR...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
