1972 Ford 4000 Select-O-Speed Problems
/ 1972 Ford 4000 Select-O-Speed Problems #1
skyrabian
Florissant, Colorado
Ford 4000
I have a Ford 4000 farm tractor. It has a 3 cylinder diesel and a 10 speed select-o-matic transmission. Recently I have lost Reverse 2 and Forward gears 3,4,7,8 and 10. Reverse 1 and Forward gears 1,2,5,6 and 9 still work. Does anyone know what this symptom means and what it would take to repair? Is there any Ford service specialist out there? Thanks, Ken
/ 1972 Ford 4000 Select-O-Speed Problems #2
did you check out the sos troubleshooting tips link?
/ 1972 Ford 4000 Select-O-Speed Problems #3
I too have a SOS (Select-O-Speed) transmission on my '65 Ford 3000 gas burner. I haven't had it very long but I'm learning fast thanks to some expert help here on this forum including SoundGuy above and RickB. I've found having a Ford I&T shop manual (NO. FO-31) is invaluable, I recommend getting one if you haven't already. I found mine on eBay for around $25 shipped.
In the manual is a chart (page 81) that shows reverse 2 and forward gears 3,4,7,8 and 10 are all related to transmission Unit #1 (Servo #1 and Band #1). This would lead me to believe that Unit #1 may be out of adjustment in your case. Also in the manual a control valve adjustment is recommended in the step-by-step outline of the testing and adjustment procedures. To perform the procedures you need a hydraulic pressure gauge. I intend to purchase one myself ASAP.
If it hasn't already been done I would first check the fluid level and clean the lower pump filter screen. I'd also recommend replacing the main transmission filter (NH # 309735) and the fluid (AMBRA 134G), both available at the New Holland dealer, about $110 for all.
SouNdguy; I did try that link. It had a symptom similar to mine, but it was reversed. I wrote to smith8n on that site and he told me that it sounded like #1 band. I have not had a chance to check it out yet. Thanks for your input!!
CircleRat; I do have all the service manuals, but I thought that I would try just asking first. Sometimes those service manuals seem like they were written in some other language! Now that I have a direction, I will see if I can interpret the manual! Thanks for your input as well!!
/ 1972 Ford 4000 Select-O-Speed Problems #5
yup, because it's NOT the orc issue.. band 1, is looking good.
1998 CHEVROLET C7500 (INOPERABLE) (A67714)
1998 CHEVROLET...
2023 Kubota L4802DT 4WD 48HP Utility Loader Tractor (A66734)
2023 Kubota...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
