1967 Mitsubishi S-670 D
   / 1967 Mitsubishi S-670 D #1
sarayeager
SPRING
Mitsubishi Satoh S 670 D
I am looking for 2 front rims for 7-16 tires. Mine have bad rust spots at the stems.
I am also looking for 2 other parts. 1. The mushroom shaped cap for the air intake
and
2. The 90 degree part that bolts to the engine block that the muffler mounts onto.
Anybody know where I can find these?
   / 1967 Mitsubishi S-670 D #2
Them rims are scarce and high. You could have old hole welded up and drill another hole somewhere else. Or cut center of rim out and weld another rim to your center.
   / 1967 Mitsubishi S-670 D #4
and
Deere LVA13634 rims. According to online specifications, they are 5X14 rims size with 6X6” bolt circle and 4 5/8 center pilot hole. These specs are identical to the original Satoh Mitsubishi spec’d rims for the S670D.
Not sure if the 4WD front rim would work on a 2WD, but the Deere rim fits.
If the rims don't match, then there is a company that will get you there with new ones.
2015 John Deere Z915B Zero-Turn Mower (A36338)
2015 John Deere...
3pt 6' Box Blade (A34127)
3pt 6' Box Blade...
Unused 2024 Greatbear Qty of (5) 9200LBS Ratchet binder and Qty of (10) 3/8" 20FT G70 chain (A36338)
Unused 2024...
Powermate Model PMO496500 Generator W/Honda Engine (A36602)
Powermate Model...
2016 CASE IH 2250 Sprayer (A35465)
2016 CASE IH 2250...
2007 Kubota M108S (A35780)
2007 Kubota M108S...
