1967 Mitsubishi S-670 D
   / 1967 Mitsubishi S-670 D #1
sarayeager
SPRING
Mitsubishi Satoh S 670 D
I am looking for 2 front rims for 7-16 tires. Mine have bad rust spots at the stems.
I am also looking for 2 other parts. 1. The mushroom shaped cap for the air intake
and
2. The 90 degree part that bolts to the engine block that the muffler mounts onto.
Anybody know where I can find these?
   / 1967 Mitsubishi S-670 D #2
Them rims are scarce and high. You could have old hole welded up and drill another hole somewhere else. Or cut center of rim out and weld another rim to your center.
   / 1967 Mitsubishi S-670 D #4
and
Deere LVA13634 rims. According to online specifications, they are 5X14 rims size with 6X6” bolt circle and 4 5/8 center pilot hole. These specs are identical to the original Satoh Mitsubishi spec’d rims for the S670D.
Not sure if the 4WD front rim would work on a 2WD, but the Deere rim fits.
If the rims don't match, then there is a company that will get you there with new ones.
1999 Ford E250 Van Truck, (A35430)
1999 Ford E250 Van...
Unused 2024 7FT Work Bench with 20 Drawers (A36338)
Unused 2024 7FT...
2020 RoGator RG1300C Precision R2 Air Max Spreader (A35465)
2020 RoGator...
2005 Ford E350 Phoenix Cruiser RV (A35915)
2005 Ford E350...
10'x20' Hercules Steel Frame Canopy (A36602)
10'x20' Hercules...
Unused 2024 Greatbear 20ft Bi-Parting Iron Gate. With artwork "Star" in the Middle of Gate Frame (A35780)
Unused 2024...
