1967 Ford 3400 3PT issues
/ 1967 Ford 3400 3PT issues #1
plrinaldo
Fenwick Ontario
1967 Ford 3400
Been having ongoing problems with the 3pt. Worked for a while after i changed the filters and fluids in the rear sump however power to the 3pt remained intermittent. Then the 3pt stopped completely and the pump failed (blew some seals) .Pump has been rebuilt and tested but 3pt still doesnt work. I have tried priming the pump using various tips on here with no luck:(.. Not seeing any hydraulic fluid at the pump at all.
I am suspecting or rather hoping that there perhaps is a problem in the hydraulic suction line. I dont see any obvious leaks but the suction line has 2 dents in it squishing the line to about half its normal diameter. I have a replacement hydraulic line coming and will be inspecting the rear sump and seals again since ill be draining it to change the hydraulic line. Any other ideas?
