1967 2000 Light Options
/ 1967 2000 Light Options #1
gb6049
Bethpage, TN
1967 Ford 2000
When I bought my 1967 model 3000 it only had one original headlight and a work light mounted for the other. Neither worked. I found replica replacements and had added those but in trying to trace the wiring and the switch connections makes me ask what lights would a Basildon, England tractor have come with?
The switch is a multi position rotary type. There are 2 wires running to the front. I figured it might have been for high and low beam. The light I bought are single element so I plan to add an additional LED light bar on the bumper.
One wire goes to the dash lights that I need to replace.
One wire runs to the rear fenders where fender lights would have been. I going to mount some dual faced red / Amber with dual elements on each fender. I plan to add a flasher relay for the brake/ turn and have separate running light.
I also will be adding a LED work light or maybe a light bar facing rearward.
That still leaves me asking the question of what lights were originally installed and how were they wired. Can anyone help ? Maybe some photos of fender light set up?
/ 1967 2000 Light Options #2
Google FORD 3000 Tractor (Images) There's a ton!
Seems, most of the headlamps were front mounted.
Replacing the headlights on the front cowl and lights on the fenders is no problem. I am more interested in how they operated in relation to the 1 off 4 on switch with 5 lugs. The pictures don稚 tell me that and I have a hard time finding a replacement switch.
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2014 Ram 1500 4x4...
2019 VERMEER LP573 XDT VACUUM TRAILER (A59823)
2019 VERMEER LP573...
2020 Toyota Tacoma Crew Cab Pickup Truck (A59230)
2020 Toyota Tacoma...
1981 Mack DM492S T/A Flatbed Fuel Transport Truck (A59230)
1981 Mack DM492S...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A59908)
2016 INTERNATIONAL...
2021 Dodge Charger Sedan (A59231)
2021 Dodge Charger...
