1967 2000 Light Options
/ 1967 2000 Light Options #1
gb6049
Bethpage, TN
1967 Ford 2000
When I bought my 1967 model 3000 it only had one original headlight and a work light mounted for the other. Neither worked. I found replica replacements and had added those but in trying to trace the wiring and the switch connections makes me ask what lights would a Basildon, England tractor have come with?
The switch is a multi position rotary type. There are 2 wires running to the front. I figured it might have been for high and low beam. The light I bought are single element so I plan to add an additional LED light bar on the bumper.
One wire goes to the dash lights that I need to replace.
One wire runs to the rear fenders where fender lights would have been. I going to mount some dual faced red / Amber with dual elements on each fender. I plan to add a flasher relay for the brake/ turn and have separate running light.
I also will be adding a LED work light or maybe a light bar facing rearward.
That still leaves me asking the question of what lights were originally installed and how were they wired. Can anyone help ? Maybe some photos of fender light set up?
/ 1967 2000 Light Options #2
Google FORD 3000 Tractor (Images) There's a ton!
Seems, most of the headlamps were front mounted.
Replacing the headlights on the front cowl and lights on the fenders is no problem. I am more interested in how they operated in relation to the 1 off 4 on switch with 5 lugs. The pictures don稚 tell me that and I have a hard time finding a replacement switch.
500BBL WHEELED...
2016 Autocar Xpert New Way 13RLC 13yd Rear Loader Garbage Truck (A59230)
2016 Autocar Xpert...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
500BBL WHEELED...
2016 FORD F-550 XL SUPER DUTY UTILTY/SERVICE TRUCK (A59823)
2016 FORD F-550 XL...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
