1963 John Deere 4010 Syncro-range shifter rebuild kit
   / 1963 John Deere 4010 Syncro-range shifter rebuild kit #1
jrsavoie
Platinum Member
Clifton, Illinois
1975 Ford backhoe/loader 3 cylinder diesel, 2022 Kubota LX2610, 1963 John Deere 4010 diesel wide front, 1996 Toro 223D Groundsmaster, 1998 Toro Groundsmaster 325D 4x4 72" deck cab & snowblower
Where do I find a rebuild kit for a 1963 John Deere 4010 Syncro-range shifter? Or do I need to order each part by itself?
Where do I find a good schematic with part numbers?
Are there any good tutorials for tearing into one of these?
I have a couple of gears that do not seem to play nice. I think the reverse below 5th gear and one other.
I backed up in the reverse below 3rd gear.
Any advice would be appreciated.
I went to the link below, but it was so hard to see, that I wasn't sure I was looking at the correct picture
John Deere Parts Catalog
   / 1963 John Deere 4010 Syncro-range shifter rebuild kit #2
Are your shifting linkages showing lots of slop? Ken Sweet
   / 1963 John Deere 4010 Syncro-range shifter rebuild kit #3
jr
Try this jdparts link.
John Deere - Parts Catalog
Enter your model no. and go to the different listings.. expect better quality than what you linked to in your post.
Give it a shot.
Also, can visit your Deere dealer for the same help.
I haven't really looked at it yet.
If the shifter linkages show slop, is it OK to drill them out to the next size bigger pin or can that present a different issue?
   / 1963 John Deere 4010 Syncro-range shifter rebuild kit #5
I had success with doing that. Tks, Ken
   / 1963 John Deere 4010 Syncro-range shifter rebuild kit #6
There is no "kit" that I am aware of. Here is a diagram of the parts. Usually, replacing bushings #10, pivot #15, latch #6 and any other obviously worn parts makes a world of difference in shifting
Thank you much!!
My Parts book - Has the similar picture, but Different item numbers for the same parts
I am on page 35-7 of Parts Catalog No. PC-691
I have the Peaceful Creek LLC parts manual. Is it possible they used different numbers to avoid copyright infringement?
The part numbers are also different.
From the link above I have part number #6 Latch - pt# R52882 #10 Bushing - 2 Ea. pt# R26182 #14 1/4"x 1 1/4" roll pins 2 ea. Pt# 34H314 #15 Pivot R53247
John Deere 42 Synchro-range shifter rebuild - zeketheantiquefreak - YouTube
   / 1963 John Deere 4010 Syncro-range shifter rebuild kit #9
Key 6 latch correct part number is R52882
Thank you much. I edited my post. Bonus. The local dealer has everything in stock.
2015 Hooper Trailer and Foaming Unit (A50860)
2015 Hooper...
2019 Ford F-150 4X4 (A50397)
2019 Ford F-150...
New/Unused 2025 CFG MX12RX Mini Excavator (A48837)
New/Unused 2025...
Adams Conveyor (A50397)
Adams Conveyor...
UNUSED LANDHONOR HYD HAY ACCUMULATOR GRAPPLE (A50460)
UNUSED LANDHONOR...
Case 580 SuperK Loader Backhoe (A50860)
Case 580 SuperK...
