1963 John Deere 4010 Syncro-range shifter rebuild kit
/ 1963 John Deere 4010 Syncro-range shifter rebuild kit #1
jrsavoie
Clifton, Illinois
1975 Ford backhoe/loader 3 cylinder diesel, 2022 Kubota LX2610, 1963 John Deere 4010 diesel wide front, 1996 Toro 223D Groundsmaster, 1998 Toro Groundsmaster 325D 4x4 72" deck cab & snowblower
Where do I find a rebuild kit for a 1963 John Deere 4010 Syncro-range shifter? Or do I need to order each part by itself?
Where do I find a good schematic with part numbers?
Are there any good tutorials for tearing into one of these?
I have a couple of gears that do not seem to play nice. I think the reverse below 5th gear and one other.
I backed up in the reverse below 3rd gear.
Any advice would be appreciated.
I went to the link below, but it was so hard to see, that I wasn't sure I was looking at the correct picture
John Deere Parts Catalog
/ 1963 John Deere 4010 Syncro-range shifter rebuild kit #2
Are your shifting linkages showing lots of slop? Ken Sweet
/ 1963 John Deere 4010 Syncro-range shifter rebuild kit #3
jr
Try this jdparts link.
John Deere - Parts Catalog
Enter your model no. and go to the different listings.. expect better quality than what you linked to in your post.
Give it a shot.
Also, can visit your Deere dealer for the same help.
I haven't really looked at it yet.
If the shifter linkages show slop, is it OK to drill them out to the next size bigger pin or can that present a different issue?
/ 1963 John Deere 4010 Syncro-range shifter rebuild kit #5
I had success with doing that. Tks, Ken
/ 1963 John Deere 4010 Syncro-range shifter rebuild kit #6
There is no "kit" that I am aware of. Here is a diagram of the parts. Usually, replacing bushings #10, pivot #15, latch #6 and any other obviously worn parts makes a world of difference in shifting
Thank you much!!
My Parts book - Has the similar picture, but Different item numbers for the same parts
I am on page 35-7 of Parts Catalog No. PC-691
I have the Peaceful Creek LLC parts manual. Is it possible they used different numbers to avoid copyright infringement?
The part numbers are also different.
From the link above I have part number #6 Latch - pt# R52882 #10 Bushing - 2 Ea. pt# R26182 #14 1/4"x 1 1/4" roll pins 2 ea. Pt# 34H314 #15 Pivot R53247
John Deere 42 Synchro-range shifter rebuild - zeketheantiquefreak - YouTube
/ 1963 John Deere 4010 Syncro-range shifter rebuild kit #9
Key 6 latch correct part number is R52882
Thank you much. I edited my post. Bonus. The local dealer has everything in stock.
/ 1963 John Deere 4010 Syncro-range shifter rebuild kit #11
jd110 - Thanks for the parts info. I had a lot of slop in my 3010 D syncro-range shifter and some gears were getting almost impossible to engage. I ordered exactly the parts you identified (Green Parts Store had them) and when I disassembled the syncro-shifter assembly, found wallowed-out holes in the old parts and the bronze sleeve bushings quite worn. With those parts replaced (2-3 hour job) it now works great. Can easily select any gear.
/ 1963 John Deere 4010 Syncro-range shifter rebuild kit #12
Great! glad to have been some help.
2018 Chevrolet Cruze Sedan (A61569)
2018 Chevrolet...
2024 GMC Sierra Elevation Crew Cab 4X4 Pick-Up Truck (A60352)
2024 GMC Sierra...
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
John Deere 6110M (A60462)
John Deere 6110M...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2010 Deere 318D (A60462)
2010 Deere 318D...
