1953 Fergurson TO-30 choke replacement?
   / 1953 Fergurson TO-30 choke replacement? #1
1950FergieMike
Snohomish, WA
1950 Ferguson
I can't get the choke to work after rebuilding the carb. The flapper won't flap. I put it back together every way possible and it won't move. What am doing wrong?
   / 1953 Fergurson TO-30 choke replacement? #2
G'day don't know how you could get it wrong you pull the choke knob and the butterfly shuts!! Don't mean to sound rude but I cant think of any way you could go wrong can you put up a pic of your carb and linkages we might be able to see the problem.
Jon
   / 1953 Fergurson TO-30 choke replacement? #3
did you put the butterfly on the wrong side of the choke shaft?
install shaft opposite side?
I can't install the butterfly on the wrong side of the shaft because the screws are on the outside side of the throat. Can't install shaft on wrong side because its only open on one side.
I posted a couple pictures. The choke shaft will not move when installed like the pictures or with the butterfly other other way with the 10 at the top. The 01 in at the bottom in the picture. It won't move in either direction.
   / 1953 Fergurson TO-30 choke replacement? #8
G'day I have to agree with soundguy I think, I reckon the butterfly screws onto the other side of the shaft will be a PITA to put the screws in but I think he is right. I thought I might have had a carb here I could look at but can't find one.
Jon
   / 1953 Fergurson TO-30 choke replacement? #9
Jon
only reason i mention it is i have bought a rebuilt carb that had it on like that... :)
   / 1953 Fergurson TO-30 choke replacement? #10
I'm thinking you need to remove the choke disc, let the choke shaft rotate ahead a bit, getting past center, then reattach the disc. Aren't the choke disc's elongated a tad, so as to pretty much close the hole at a slight angle..??
Looking at generic pics of a TO20's carbs, the tang on the choke shaft is rotated forward a good bit. And being the return spring on yours has it at full choke, I'm guessing the disc is elongated enough to prevent it going on O.C.
Granted, you may have to release the return spring, or hold the tang with your finger, until you get the disc reattached, but thinking that is the problem.
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2013 John Deere Gator 825E (A51573)
2013 John Deere...
1994 Fiat Allis 65-B Motor Grader (A52384)
1994 Fiat Allis...
2013 Nissan Rogue SUV (A51694)
2013 Nissan Rogue...
RoGator RG1300C Air Max Precision 2 Spreader (A53342)
RoGator RG1300C...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
