1950 allis chalmers wd
/ 1950 allis chalmers wd #1
Birchhatchery
bfe
in search of new iron
I was wondering how do I check the rear end fluid? and were is the fill hole and how much engine oil does it hold and how much rear end oil does it hold and how much radiator fluid does it hold thanks
/ 1950 allis chalmers wd #2
This is from another old machinery forum, but it sounds similar to what I remember. My grandfather had a WD, but last time I helped service it I was about 14-15 years old. I don't remember how much coolant or engine oil it holds.
There are 4 drain plugs.
Starting at the rear is the diff drain, that's the one you drained.
Second one is under the trans.
Third one is at bottom of PTO drop box.
These 3 are connected internally, but have a partial divider, so need to drain all 3 before filling any of them.
There are 2 filler plugs on left side of trans case, close to the left frame rail, square headed pipe plugs. Hard to get to with open end wrench. I use a 12 point socket & extension, think 7/8 on rear plug, 3/4 on forward plug. Use 80W-90 or 140 gear lube. Can fill in one plug, but takes some time for lube to pass the internal dividers, so quicker to fill at both plugs. Takes 17 quarts.
Fourth drain plug is Hydraulics & belt pulley drive, forward of PTO, but rearward of engine clutch. This compartment is NOT connected to the trans clutch/ trans/ diff compartment. Filler is also on left side, that little cap with dipstick attached. Use any hyd fluid or 20W engine oil.
I figured all that but I don't see a place with it has a check plug or anything on it I just obtained the tractor yesterday at a pull and I don't see a place to check the rear end fluid
does it even have a oil check plug?:
