1993 ford 1920 3point hitch wont raise
   / 1993 ford 1920 3point hitch wont raise #1
tfordala
anniston,al
internation 464
I have fluid to the rear but moving the handles and lift does nothing..I have a front end loader on it and it works slow if you rev up engine..how much pressure does it need to make the 3 point hitch work?
   / 1993 ford 1920 3point hitch wont raise #2
With nothing attached, the 3pt should lift easily. Is this a new problem? Was the 3pt working before?
Check or change your hydraulic filter
It just quit working alltogether im not sure of the fluid pressure from the pump but FEL works slow but a bit faster if you rev up engine.
   / 1993 ford 1920 3point hitch wont raise #4
Hard to diagnose from here other than to say the pump is bad. Is the loader jerky, hesitant? Is there noise from the pump? You may be bypassing somewhere in the system or the pump itself had something come apart.
2001 CATERPILLAR D400E 6X6 OFF ROAD DUMP TRUCK (A60429)
2001 CATERPILLAR...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
2014 CATERPILLAR 299D SKID STEER (A60429)
2014 CATERPILLAR...
UNUSED RAYTREE RMBD72ST-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Deere 323E (A53317)
2018 Deere 323E...
