1993 ford 1920 3point hitch wont raise
   / 1993 ford 1920 3point hitch wont raise #1
tfordala
anniston,al
internation 464
I have fluid to the rear but moving the handles and lift does nothing..I have a front end loader on it and it works slow if you rev up engine..how much pressure does it need to make the 3 point hitch work?
   / 1993 ford 1920 3point hitch wont raise #2
With nothing attached, the 3pt should lift easily. Is this a new problem? Was the 3pt working before?
Check or change your hydraulic filter
It just quit working alltogether im not sure of the fluid pressure from the pump but FEL works slow but a bit faster if you rev up engine.
   / 1993 ford 1920 3point hitch wont raise #4
Hard to diagnose from here other than to say the pump is bad. Is the loader jerky, hesitant? Is there noise from the pump? You may be bypassing somewhere in the system or the pump itself had something come apart.
TEST YOUR BID BUTTON! (A52706)
TEST YOUR BID...
2012 John Deere Z925A 60in Zero Turn Commercial Mower (A52377)
2012 John Deere...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
