1947 Ford 2N won’t start
   / 1947 Ford 2N won’t start #1
Tbaker59
I’ve tried everything I know. New plugs, wires, cap, rotor, points, condenser. Bought a new ignition coil and rebuilt the carburetor. Removed and cleaned the fuel sediment bowl. Verified plugs are sparking and fuel is going to the carburetor. I suppose there’s a chance I could have put the distributor in 180 degrees out, but I doubt it. Please help.
   / 1947 Ford 2N won’t start #2
How's your compression ?
   / 1947 Ford 2N won’t start #4
I haven’t checked that. What number am I looking for?
Not sure but look it up and see how to check the compression for your engine, usually just pull the plugs, a gauge in the spark plug hole, turn it over.
You will need compression gauge, and a reading in all of the cylinders, record them, squirt in some oil and check it again, record the numbers.
If the numbers go up, then it could be rings, if the compression stays the same, then it could be valves or a head gasket.
If lower then it should be then you might have a stuck valve(s), so many things, check it first, then make a decision on the next move.
Without compression there is no Big Bang or at least not what you need.
   / 1947 Ford 2N won’t start #5
Compression should be 90 psi. Does it sound like it wants to kick over at all?
2016 JLG 3248RS Electric Scissor Lift (A56857)
2016 JLG 3248RS...
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2019 Ford F-550...
2021 Bronco 255K XD Welder Generator (A55973)
2021 Bronco 255K...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
