1947 Ford 2N won’t start
   / 1947 Ford 2N won’t start #1
Tbaker59
I’ve tried everything I know. New plugs, wires, cap, rotor, points, condenser. Bought a new ignition coil and rebuilt the carburetor. Removed and cleaned the fuel sediment bowl. Verified plugs are sparking and fuel is going to the carburetor. I suppose there’s a chance I could have put the distributor in 180 degrees out, but I doubt it. Please help.
   / 1947 Ford 2N won’t start #2
How's your compression ?
   / 1947 Ford 2N won’t start #4
I haven’t checked that. What number am I looking for?
Not sure but look it up and see how to check the compression for your engine, usually just pull the plugs, a gauge in the spark plug hole, turn it over.
You will need compression gauge, and a reading in all of the cylinders, record them, squirt in some oil and check it again, record the numbers.
If the numbers go up, then it could be rings, if the compression stays the same, then it could be valves or a head gasket.
If lower then it should be then you might have a stuck valve(s), so many things, check it first, then make a decision on the next move.
Without compression there is no Big Bang or at least not what you need.
   / 1947 Ford 2N won’t start #5
Compression should be 90 psi. Does it sound like it wants to kick over at all?
2025 AGT MX15RX Mini-Excavator with Dozer Blade (New/Unused) (A59225)
2025 AGT MX15RX...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
backhoe attachment for full size skid steer (A56857)
backhoe attachment...
2010 KENWORTH T660 TANDEM AXLE MID ROOF SLEEPER (A58017)
2010 KENWORTH T660...
2008 Jeep Wrangler 4X4 SUV (A56859)
2008 Jeep Wrangler...
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
