1942 d4 CAT
/ 1942 d4 CAT #1
dlopez
Kubota RTV 1100
I have had a problem with the trans oil leaking out of my '42 d4 dozer. It is coming out of a hole on the bottom of the trans and I don't know if that is a bell housing drain or if it is missing the plug. It only leaks a little at a time due to a sponge like material holding most of it in. If anyone knows if I need to plug that or if my main seal is shot and that's why its leaking, please give me your advise. Thanks.
/ 1942 d4 CAT #2
I've been running my Dad's 1951 Allis Chalmers HD5 (about the size of a Cat D3) for a couple of months and it has pretty much the same problem. I suspect a seal is bad, but considering its age and that it still runs like a top, I just add 80-90 gear oil once a week and call it good. If I was relying on it in a business situation I would certainly have it fixed. For my occasional use a little spilled oil is nothing to worry about.
I did not answer your question, but I hope this helps.
/ 1942 d4 CAT
That is almost exactly what I do, just add 80-90 every time I use it which is occasional. IT runs like a champ and does amazing! I love it and at some point will fix it. Thanx for the confidence that wat I'm doing isn't very bad.
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
Adams Tilt Trailer (A63688)
Adams Tilt Trailer...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
