185 Hydro starting intermittently
/ 185 Hydro starting intermittently #1
Fun2cycle
185 hydro
Looking for assistance and/or electrical diagram to help troubleshoot. Press brake and turn key, starter will not engage. I know there is a safety switch attached to the brake petal, switch tests ok. Is there a switch attached to the hydrostatic lever, for a neutral position?
Appreciate any help I can get.
Thanks,
Tom
/ 185 Hydro starting intermittently #2
Welcome to TBN
Are you saying starter doesn't make a sound (like a click) or it spins but doesn't engage the flywheel to turn over the engine?
I will confirm that this evening and post a reply. Stand by….
/ 185 Hydro starting intermittently #4
Also, what does "intermittently" mean in the subject line??
When I press the brake and turn the key it does click but will not spin the starter. Is it possibly solenoid issue?
/ 185 Hydro starting intermittently #6
First remove and replace battery cable connections after cleaning each at both ends. Also consider getting a new battery or at least get this one load tested.
This is based on the OP comment "it does click but will not spin the starter". Sounds battery 12v related.
/ 185 Hydro starting intermittently #7
Thanks,
Tom
The John Deere Part number is AM107421 and will cost about $50 plus tax. Or use the diagram and source the parts from a auto zone store or other parts house.
I will give this a try and let you know. It will be a few days before I can get to it though.
@beenthere I cleaned the battery connections and tested the battery, battery was good. Still same issue.....Then I removed the wiring plug at the ignition switch, sprayed contact cleaner and cleaned a few of the spades on the ignition switch, replaced connector and now it seems to start every time I hit the switch..... Guess it was a bad connection at the ignition switch... And thanks for your help and suggestions....Tom
Caterpillar Tractor-Scraper Service Manuals (A63117)
Caterpillar...
2013 Infiniti JX35 AWD SUV (A61574)
2013 Infiniti JX35...
Industrias America 435 (A64119)
Industrias America...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
