185 Hydro starting intermittently
/ 185 Hydro starting intermittently #1
Fun2cycle
185 hydro
Looking for assistance and/or electrical diagram to help troubleshoot. Press brake and turn key, starter will not engage. I know there is a safety switch attached to the brake petal, switch tests ok. Is there a switch attached to the hydrostatic lever, for a neutral position?
Appreciate any help I can get.
Thanks,
Tom
/ 185 Hydro starting intermittently #2
Welcome to TBN
Are you saying starter doesn't make a sound (like a click) or it spins but doesn't engage the flywheel to turn over the engine?
I will confirm that this evening and post a reply. Stand by….
/ 185 Hydro starting intermittently #4
Also, what does "intermittently" mean in the subject line??
When I press the brake and turn the key it does click but will not spin the starter. Is it possibly solenoid issue?
/ 185 Hydro starting intermittently #6
First remove and replace battery cable connections after cleaning each at both ends. Also consider getting a new battery or at least get this one load tested.
This is based on the OP comment "it does click but will not spin the starter". Sounds battery 12v related.
/ 185 Hydro starting intermittently #7
Thanks,
Tom
The John Deere Part number is AM107421 and will cost about $50 plus tax. Or use the diagram and source the parts from a auto zone store or other parts house.
I will give this a try and let you know. It will be a few days before I can get to it though.
@beenthere I cleaned the battery connections and tested the battery, battery was good. Still same issue.....Then I removed the wiring plug at the ignition switch, sprayed contact cleaner and cleaned a few of the spades on the ignition switch, replaced connector and now it seems to start every time I hit the switch..... Guess it was a bad connection at the ignition switch... And thanks for your help and suggestions....Tom
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2019 Toro...
2022 EZ-GO ELITE...
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2018 Mitsubishi Mirage Hatchback (A64557)
2018 Mitsubishi...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
